Problem: When I check my output as HTML5 format, on any browser I have (Edge, Chrome) the font is out of its frame. In my projet, the font is Inside.
ActivePresenter Version:
OS: Win 10
OS: Win 10
You’ve solved this issue yourself, but I just update it here just in case it may be helpful for other users.
The root of the issue is that the font using in this project has been deleted after updating Windows:
