2
00:00:02,220 → 00:00:06,140
puede programar su robot VR para hacer muchas cosas.
3
00:00:06,140 → 00:00:10,270
Cada proyecto comienza con un bloque Cuando Empieza.
Note: If you create a subtitle file by a certain application (Ex: Aegisub), before exporting subtitles to SRT file, make sure you select Unicode(UTF-8) encoding.
It seems that you type the format of the timecodes in your SRT file wrongly.
The correct format should be: hours:minutes:seconds,milliseconds
Kindly note that a comma is used instead of a dot to separate the seconds and milliseconds.
