Problem: my laptop crashed before i could save a file and now it shows error project_1.approj could not be opened. However, project1_files are saved in my laptop, is there any way to fix this so i could get my recording back?
You can create a new project from the video, audio in the project1_files folder.
Besides, kindly take note that ActivePresenter is mainly designed for creating training tutorials that normally have a duration of fewer than 1 hour.
If you want to record a long session, you should look around for other screen recorders on the Internet.
Click Open Project in ActivePresenter, and select the video in project1_files folder.
It’ll create a new project from your video.
Select Insert > Audio to insert the audio in project1_files folder to this new project.
Or you can drag the audio file into Canvas area of this new project.
