Hi, could you someone let me know or direct me where I can find the answer to how I can create the feedback layout boxes that are used in the Catch Bubbles Demo? I mean the box that pops up when answering a question correctly or falsely?
Regarding the Catch Bubbles demo, after downloading the sample, you can navigate to View tab > Slide Master.
All of the interactions for the feedback messages are set here.
However, to more conveniently adjust, you should consider using Feedback Master.
You can find more information about using the Feedback Master feature from the tutorial below:
