Problem: I added fade-in and fade-out to an arrow. Works fine. In between fade-in/fade-out, I want the arrow to drop down (straight line motion) and point to another section. Fade-in and motion work fine. But fade-out is converted to just disappearing.
We followed your steps but can’t reproduce the issue.
It would be helpful if you can share a project having the issue and its external data folder named in the PROJECT_FILE_files to support@atomisystems.com so that we can check.
Thanks for sharing the project file.
We confirm this is a bug in ActivePresenter 8.5.5 on macOS. We will try to fix and release an update soon.
We are sorry for this inconvenience.
