When I use lower volume in some specified ranges (silenced because narrator audio) for background music, it always gives step change. What do you think about adding final volume value setting for Fade Out and similarly initial volume for Fade In? For example, I use volume 100 for background music, but this value is changed to 30, when narrator begin talk. Using Fade Out with value 30 (instead 0) at the end of fade out, allows on smooth fade between range with volume 100 and range 30 and vice versa.
Hi Janusz,
Thanks for your suggestion. We will add this into our TODO list.
Hi Janusz,
Unfortunately, the current version of ActivePresenter hasn’t supported this feature yet. Hopefully it will be supported in the next version.
Hello,
Thank you!
Janusz
