Problem: O processamento de um projeto, já exportado em versão anterior, nunca termina. Chega um momento que para e não continua mais, já deixei por 8 horas.
ActivePresenter Version: 8.0.5 (Lançado: 10 de abril de 2020)
Hi Bruno,
It is a known issue in 8.0.5 when exporting some projects. Can you please try setting frame rate to different values (15, 25, 30…) to see if it works?
Com taxa 25 deu o mesmo problema, com taxa 20 processou mais mas parou também e com 15 parou no mesmo lugar de 30 e 25
Essas msg são constantes no log
2020-04-14 07:17:16: s16 sample format is not supported, fltp will be used
2020-04-14 07:17:16: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
Hi Bruno,
Can you please share the project and its external data folder named in the PROJECT_FILE_files pattern if any so we can check? If these files are large, please upload them to a cloud storage site like Google Drive then send the link to us. You can email it to support@atomisystems.com
