Export HTML5 doesn't use specific fonts
Hi, when using an HTML5 exported project, font’s files are exported in \resources, as .woff files, but are not accessed by html. They are notified in css file…
Do you know how to use them correctly ?
Thanks
ActivePresenter version: 9.0.1
OS: Win10
Can you please share your project along with its external data folder named in the form PROJECT_FILE_files (if any) like below to our email at support@atomisystems.com so we can further check it?
In case your project does not include an external data folder, please only send us the project file.
If these files are large, you can upload them to a cloud storage site like Google Drive and share the download link with us.
Besides, kindly let us know which browser you are using in this case.
Best regards,
Hang
Hello. I will try sharing part of the project quickly…
The bug is not browser’s dependant : display is the same with chrome and edge for example.
Fonts are correctly displayed in AP’s Preview mode, but not with the exported HTML5 project executed by double-click
PB
I’ve responded to your email.
Kindly take a moment to check it out.
