Hello.
I have a problem with a button with custom javascript.
I made the “Exit” button works correctly in test mode.
However when exporting to Scorm, the button closes the project but does not close the browser window.
Here is the code used:
window.close ();
The script window.close (); only helps to close the browser tab which is opened by script. Therefore, you should configure to open your course in a new window/tab when uploading the SCORM package to the LMS for the script to work.
