ActivePresenter version: ActivePresenter Pro Edition
Version 8.3.2 - 64-bit build. (Released: 2021.01.26)
OS: Windows 10 Pro
Notes: Error while converting closed captions to Audio, Do you want to abort?
This the reply or the issue which pops up every time i try to convert the text to voice,
This makes really annoying to use this software,
The text to speech is the main reason i purchased this software and it hardly works.
I am experiencing this now. As far as I can tell, the conversion works for the first slide then the rest donât convert. Is there some way of reviewing the log so I can work out why it is happening to fix it?
Thanks!
Thank you. I have narrowed down the error to work out it only affects one slide. The log saysâŠ
2022-03-02 11:23:35: Preparing to play audio to: Speakers (Realtek(R) Audio). Channel: 2. Sample rate: 44100. Sample Format: 8
2022-03-02 11:23:36: Audio frames decoding started.
2022-03-02 11:24:34: Azure Text-to-Speech message: An error occurred while parsing EntityName. Line 1, position 120.
2022-03-02 11:24:34: Error while start speaking text
2022-03-02 11:24:50: Azure Text-to-Speech message: An error occurred while parsing EntityName. Line 1, position 120.
2022-03-02 11:24:50: Error while start speaking text
2022-03-02 11:24:58: Azure Text-to-Speech message: An error occurred while parsing EntityName. Line 1, position 120.
2022-03-02 11:24:58: Error while start speaking text
2022-03-02 11:30:19: Azure Text-to-Speech message: An error occurred while parsing EntityName. Line 1, position 120.
2022-03-02 11:30:19: Error while start speaking text
2022-03-02 11:30:30: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2022-03-02 11:35:48: Azure Text-to-Speech message: An error occurred while parsing EntityName. Line 1, position 120.
2022-03-02 11:35:48: Error while start speaking text
I am using the exact same âvoiceâ on all the other slides and canât work out why this slide is troublesome? Thank you for investigating for me!
I have unticked SSML for all nodes. The text for each node is: 4
00:00:31,303 â 00:00:34,303
A Imdex reconhece que a saĂșde e o bem-estar de seus trabalhadores sĂŁo primordiais para alcançar o sucesso.
5
00:00:37,917 â 00:00:40,917
Ă por isso que dispomos de ferramentas para ajudar a gerenciar os riscos Ă saĂșde e ao bem-estar de nossos trabalhadores.
6
00:00:44,733 â 00:00:47,733
Esta lição cobre os seguintes tópicos:
9
00:00:57,226 â 00:01:00,226
e trabalhando em condiçÔes extremas.
10
00:01:01,280 â 00:01:04,280
Vamos começar!
I have also tried using different âvoicesâ and that isnât helping. I have recreated the slide from scratch twice and that also doesnât help. Thank you for your assistance!
