Good morning!
I could use a little help when you have time…
I’m preparing this horizontal sequence exercise, but if I use two equal letters, the error returns.
Is there a method for this not to happen?
Thank you!
Unfortunately it’s not possible with the sequence question. We’ll try to support this use case in the future release.
I think you can decorate the two letters differently, and add a note for the users that which one should come first.
You can also use a Drag-n-Drop question and allow each letter to be dropped into many drop targets.
