Hi. I encountered this error message getvalue(cml.entry) failed when launching the SCORM package in Opigno LMS. I tested the package in Scorm Cloud and it worked fine. How do I fix this?
Hi. Thanks for the response. I exported it to SCORM 1.2 and got the following error message:
**LMSGetValue(cmi.core.entry) failed. ** Not implemented error
After clicking ‘OK’, the error message pop up closed and the SCORM packaged played.
It seems your LMS doesn’t fully support SCORM 1.2 and 2004 specifications since this value is mandatory. You can take a look at page 3 - 26 at http://xml.coverpages.org/SCORM-12-RunTimeEnv.pdf for details. Please contact your LMS provider for support.
