I am trying to embed a widget into my presentation but it is not working. I have tried with some embed codes and they do work, others do not. Is there a certain type of embed code that is not compatible with Activpresenter?
So do you mean “it doesn’t work” when testing locally or when uploaded the HTML5 output to a web server?
From what I see, both the embed codes wouldn’t work when testing locally because you used Protocol-relative URL, e.g. //www.classtools.net/widg which usually cannot work locally.
Consider replacing it with either http:// or https://
I’ve tried your suggestion and it just shows a blank screen on the page when I export it to HTML 5. Also, it won’t show locally when I try and preview it.
The url should start with http://, not //http://, so the correct url in your sample is http://gynzy.com/embed/1556
Moreover, you should not paste the entire code into Embed Code filed of the web object, just paste only the url into URL field.
