Boa tarde… Li todo o tutorial e não encontrei como adicionar efeito sonoro em um objeto do projeto.
Vocês não tem esse recurso?
It seems that you are concerning about adding sound effect to an object in the project.
To do that, do as follows:
Step 1: Select an object on the Canvas.
Step 2: Go to the Properties pane > Audio tab. Then, select either an audio from your project (1) or import an audio file from your computer (2)
Step 3: Use audio effects such as fade in, fade out, audio noise reduction to improve your audio quality
Please refer the below tutorials for more infomation:
