What do you think about implementing easing methods for animation also in ActivePresenter? This is powerful feature in Saola Animation.
Hi Janusz,
Thanks for your suggestion.
ActivePresenter focuses on re-using preset animations than the detailed animation editing. We thought about a way that allows users to define custom animations from animation primitives but I am not sure that should be implemented in the editor like what Saola Animate does.
Yes, you are right, AF users usually needn’t extended animation edit features (like in Saola Animation) but some level of customization would be great.
Janusz
