I have two drag sources A and B and two drop targets X and Y.
A needs to be dragged to drop target X. On accept, this will show drop target Y. If then A is dragged to Y, on correct A moves back to its original position through .translate(0,0). All of this works fine as long as a stay in the slide.
When I exit and re-enter the slide after that the following happens:
If I move B into drop target X and B is accepted, A snaps back from its original position to drop traget X.
I tried a work around by .translate(0,0) at slide load and when drag sources are accepted to drop targets, but it seems that the last accepted drop position becomes the new originial position or something.
