Hi, I’m trying to create a drag-n-drop question with images (I’m not using the drop area from the menu but choosing drop target for an image from Interactivity → drag-n-drop) but it doesn’t work. You can’t move the connector from drag source to the drop target, it won’t accept it. And you can’t set the correct option from the Interactivity → Accept List, there’s no option for it. So how do I use an image as a drop target?
Hi Aytug,
The correct options (drag-drop connectors and the Correct column in the Accept List dialog) are only available for graded drag-drop interactions, including Drag-n-Drop questions in Questions tab, and Drop Area interaction in Insert tab.
You should use a Drag-n-Drop question in your case.
