I just wanted to know whether it is possible to put a DragSource onto a DropTarget by a click event and not actually by dragging it there. Just translating the DragSource by JavaScript did not work for me.
Hey @ToanLS, just a quick follow-up question. Is it possible to put the DragSource by click back on it’s original position? “Clear user input” is not working unfortunately after changing the object state for feedback.
How did you change the object state?
I see that “Clear user input” action still works after changing the drag source state (using “Change Object State” action)
