If I tick the “Drop Target” option on a shape then responses do not increase %apQuizTakenInteractions%.
It does work with “drop areas”
ActivePresenter Version: Required. 8
OS: Required. Win 10
Drop Area is different from Drop Target as described below:
Thank you
Do they both report the same way in terms of the JSON data export?
Ie. can i work out what drag source was dropped into the drop target?
