Problem: é possibile cambiare la dimensione del punto di selezione quando si seleziona un’area nelle domande hot spot?
Grazie millle per il supporto
ActivePresenter version: Versione 9.0.5 - 64-bit build
OS: Windows 10 Home
OS: Windows 10 Home
Hi Fabio,
I am not sure if I understand your question correctly.
But if you wanna change the size of the hotspots’ radius, yes, it’s very simple to do that.
Now, just do as follows:
Hope that it helps.
