Cannot find any way to use Display Order shortcuts on Mac. Key combinations work in other applications.
Thank you
Thank you
Default shortcuts for Display Order functions on macOS are as follows:
You can change to other shortcuts in ActivePresenter > Preferences > Hotkeys tab: Home > Arrange command group.
Of course I know these shortcuts, they do not work in Presenter although they work in other apps.
I made new shortcuts and it works. Hope you don’t mind, in Active Presenter 8 on Mac the menu sequence is:
ActivePresenter > Preferences > Hotkeys tab: Format > Order .
Thank you.
Have a nice day
Hi Dom,
You should use the key combination Fn + Command + Left/Right/Up/Down for the default hotkeys. We will change the default hotkeys to other appropriate keys.
