Difficulty in using object.clear() on Drag'nDrop
Hello. I can’t achieve to clear user input on a Drag’n Drop quizz.
I use prez.objet(‘DragDrop’).clear() from the manual but user’s answers are not canceled at all.
Any solution ?
Thanks. Regards
ActivePresenter version: 9.1.0
OS: Win10
For your information, the clear function executes once objects are displayed and only clears on the user interface.
Best regards,
Hi,I’m sorry but
1/ I don’t really understand your answer
2/ when I try this function with a Drag’n Drop interaction client doesn’t see every time drapped objects going “back” to their initial places…
Could you explain what is supposed to happen please ? (depending -or not- on interaction result)
Could you please share the slide where the clear function is not working with us by sending it to our dedicated support email at: support@atomisystems.com so we can check it and assist you further?
Best regards,
Hang
