There are differences in the location of some objects from the editor slides and exported video. It makes my videos look untidy. How to fix this?
Thanks,
Marika
Thanks,
Marika
Hi Marika,
It would be helpful if you can share project having the issue and its external data folder named in the PROJECT_FILE_files(if any) to support@atomisystems.com so that we can check.
If these files are large, you can upload them to a cloud storage site like Google Drive then send the download link to us.
