Hello good day.
Is there any way to edit the font for mobile and not be changed in desktop version? I would like the desktop font to be one size and the mobile font to be another.
Can you please tell which application that you are referring to? Saola Animate or ActivePresenter?
Good morning.
ActivePresenter 7.5.7
You should create a responsive project, then select the object and go to Properties > Size & Position > Transform > Text Scale.
Thanks!
