Lets say I stretch a selection area across 3 objects and all 3 are selected. How do you deselect a single item when multiple have been selected? I have tried different versions of Ctrl. Alt and Shift but can’t find the right one …?
Thanks!
Shawn
Thanks!
Shawn
Hi Shawn,
You can hold Ctrl down and click on an element to toggle its selection state without affecting other selected ones.
Thank you. I was trying to click on any of the corner dots which was not working. When I click in the center of the object itself, it works. Thanks Toan!
