I am creating a small program to calculate something. I want to display default value for the text entry box. Can you help me?
I am able to calculate using Javascript but do not know if any feature is there to display default value. Example: Text entry box value displayed by default is 5000. User will change it as per the requirement and calculated answer will change if hit enter or clicked submit button.
Thanks,
Shri
