I have an issue when adding a ’ cursor path ’ PLEASE NOTE: Adding a cursor path was working fine for the last few days, the error has just started to occur.
Example:
If I add a cursor path on slide 1 for example. ( The cursor comes off the screen and lands on a button) It seems to work fine on timeline playback.
[ THEN ] I move on to slide 2 and basically do the same thing.
And again on Slide 3. [ then I export to preview ] the cursors are all over the place following random paths.
After a closer look…
A. I noticed on Slide 1 the cursor path has randomly changed after adding a cursor path to slide 2 and again on slide 2 the cursor path randomly changes when i add a cursor path on another slide.
Im using slide 1, 2, 3 as an example it doesn’t matter which order I do it in.
Any help would be amazing
I hope this makes sense.
ActivePresenter Version: 7.3.2
OS: 10.13.6 Mac osx
