is it posiible to have re move hotspots and try again on same slide? I can have them go back to the slide on incorrect, but the selected hotspots remain on page and I cannot seem to make them g away.
Please advise.
Thank you.
Hi there,
Yes, it is possible to remove selected hotspots and try again on the same slide.
Basically, you have to ways to achieve that. Just do either of the following:
- Reclick the selected hotspot to deselect it.
- Add the Clear User Input action to the On Incorrect event of the question (Properties pane > Interactivity tab > Events - Actions section). This helps clear your previous interactions.
Have a great time,
