When I attempt to record audio for a slide or a set of slides, there is an automatic default limit of 3 seconds. Can I get rid of this?
Hi John,
It seems like you use Record Narration in the Timeline pane. You can get rid of it by doing either of the following:
Dragging the red line of a slide to the right to lengthen slide duration before recording.
Creating new audio (Insert tab > Audio > Create New > navigate to the Properties pane > click Record).
