How can I create a Lightbox? ( an image that overlays the slide)
thanks,
Cecilia
thanks,
Cecilia
Hi Cecilia,
I guess you are talking about ActivePresenter. If so, please check the attachment.
LightBox.approj (668 KB)
Thank you for the file. I had already done that, but I can’t figure out how to close the Lightbox once opened (using the same button) is that possible?
Cecilia
Hi Cecilia,
Yes, it’s possible. You should use a bool variable in condition to toggle show/hide the lightbox. Please see the attachment.
LightBox_ToggleShowHide.approj (448 KB)
thank you Nam, this is the solution I was looking for.
