Crash when changing slide names
Problem: Active presenter crashes when changing slide names
ActivePresenter Version: 7.1.0 Release 2018.02.12
OS: Windows 10 1709 64 bit
Notes: When using the slide properties to change the slide name active presenter crashes
although it doesn’t happen every time, it does happen a large percentage of the time.
      Another issue is that I can type a new name into the dialogue box and it doesn't appear as I type.
     If I switch to another slide and then back again I can see the change I made so there is some kind of refresh issue.   I have experienced a similar refresh problem when typing into various text boxes but will log that separately
We could not reproduce the issue in our tests (including the refresh issue). Can you please let us know what is the language that you used for editing text? Did you use any text input software?
