2017-09-27 09:14:53: ActivePresenter 6.1.3 (Release Build: 2017.08.19) started
OS: Mac OS X (Darwin 16.6.0 x86_64). Version: 10.12 - 64 bit
CPU Count: 8
Computer Name: Stephs-iMac.local. Memory: 16,288 MB. Available: 5,113 MB
Project Location: /Users/stephanielee/Documents/ActivePresenter/
Disk Space: 0 MB (Free: 0 MB)
2017-09-27 09:14:53: TempDir: /Users/stephanielee/Library/Application Support/ActivePresenter/temp
2017-09-27 09:24:44: flt sample format is not supported, s16 will be used
2017-09-27 09:24:44: Preparing to record audio from: Built-in Microph. Channel: 2. Sample rate: 44100. Sample Format: 8
2017-09-27 09:25:12: Start capturing. Mode: Full motion. Method: 0. Capture Size: (2560, 1440)
2017-09-27 09:25:12: Video Codec: flashsv. Expecting FPS: 30.00
2017-09-27 09:25:12: Video will be recorded to: /Users/stephanielee/Documents/ActivePresenter/RFAPL_v2_tempdir/video_20170927_09-25-12.mkv
2017-09-27 09:25:12: RLMedia: Input dimensions too large, input must be max 4095x4095 !
2017-09-27 09:25:12: VideoRecorder: Could not open output file with specified format.
2017-09-27 09:25:12: Could not start video recording
2017-09-27 09:25:37: flt sample format is not supported, s16 will be used
2017-09-27 09:25:37: Preparing to record audio from: Built-in Microph. Channel: 2. Sample rate: 44100. Sample Format: 8
2017-09-27 09:25:38: Start capturing. Mode: Full motion. Method: 0. Capture Size: (2560, 1440)
2017-09-27 09:25:38: Video Codec: flashsv. Expecting FPS: 30.00
2017-09-27 09:25:38: Video will be recorded to: /Users/stephanielee/Library/Application Support/ActivePresenter/temp/rl_20170927_092538_8jcsixl9js_tempdir/video_20170927_09-25-38.mkv
2017-09-27 09:25:38: RLMedia: Input dimensions too large, input must be max 4095x4095 !
2017-09-27 09:25:38: VideoRecorder: Could not open output file with specified format.
2017-09-27 09:25:38: Could not start video recording
2017-09-27 09:29:31: flt sample format is not supported, s16 will be used
2017-09-27 09:29:31: Preparing to record audio from: Built-in Microph. Channel: 2. Sample rate: 44100. Sample Format: 8
2017-09-27 09:29:48: Start capturing. Mode: Full motion. Method: 0. Capture Size: (2560, 1440)
2017-09-27 09:29:48: Video Codec: flashsv. Expecting FPS: 30.00
2017-09-27 09:29:48: Video will be recorded to: /Users/stephanielee/Library/Application Support/ActivePresenter/temp/rl_20170927_092948_mq954v8e4s_tempdir/video_20170927_09-29-48.mkv
2017-09-27 09:29:48: RLMedia: Input dimensions too large, input must be max 4095x4095 !
2017-09-27 09:29:48: VideoRecorder: Could not open output file with specified format.
2017-09-27 09:29:48: Could not start video recording
2017-09-27 09:41:25: flt sample format is not supported, s16 will be used
2017-09-27 09:41:25: Preparing to record audio from: Built-in Microph. Channel: 2. Sample rate: 44100. Sample Format: 8
2017-09-27 09:41:31: Start capturing. Mode: Full motion. Method: 0. Capture Size: (2560, 1440)
2017-09-27 09:41:31: Video Codec: flashsv. Expecting FPS: 30.00
2017-09-27 09:41:31: Video will be recorded to: /Users/stephanielee/Library/Application Support/ActivePresenter/temp/rl_20170927_094131_rgtwxovpjf_tempdir/video_20170927_09-41-31.mkv
2017-09-27 09:41:31: RLMedia: Input dimensions too large, input must be max 4095x4095 !
2017-09-27 09:41:31: VideoRecorder: Could not open output file with specified format.
2017-09-27 09:41:31: Could not start video recording
2017-09-27 09:41:44: ActivePresenter 6.1.3 (Release Build: 2017.08.19) shut down
2017-09-27 09:41:48: ActivePresenter 6.1.3 (Release Build: 2017.08.19) started
CPU Count: 8
Computer Name: Stephs-iMac.local. Memory: 16,292 MB. Available: 4,539 MB
Disk Space: 475,936 MB (Free: 336,039 MB)
2017-09-27 09:41:48: TempDir: /Users/stephanielee/Library/Application Support/ActivePresenter/temp
2017-09-27 09:42:19: flt sample format is not supported, s16 will be used
2017-09-27 09:42:19: Preparing to record audio from: Built-in Microph. Channel: 2. Sample rate: 44100. Sample Format: 8
2017-09-27 09:42:20: Start capturing. Mode: Full motion. Method: 0. Capture Size: (2560, 1440)
2017-09-27 09:42:20: Video Codec: flashsv. Expecting FPS: 30.00
2017-09-27 09:42:21: Video will be recorded to: /Users/stephanielee/Library/Application Support/ActivePresenter/temp/rl_20170927_094220_pbzd2oo655_tempdir/video_20170927_09-42-21.mkv
2017-09-27 09:42:21: RLMedia: Input dimensions too large, input must be max 4095x4095 !
2017-09-27 09:42:21: VideoRecorder: Could not open output file with specified format.
2017-09-27 09:42:21: Could not start video recording
2017-09-27 09:47:23: flt sample format is not supported, s16 will be used
2017-09-27 09:47:23: Preparing to record audio from: Built-in Microph. Channel: 2. Sample rate: 44100. Sample Format: 8
2017-09-27 09:47:25: Start capturing. Mode: Full motion. Method: 0. Capture Size: (2560, 1440)
2017-09-27 09:47:25: Video Codec: flashsv. Expecting FPS: 30.00
2017-09-27 09:47:25: Video will be recorded to: /Users/stephanielee/Library/Application Support/ActivePresenter/temp/rl_20170927_094725_vgdfozewdr_tempdir/video_20170927_09-47-25.mkv
2017-09-27 09:47:25: RLMedia: Input dimensions too large, input must be max 4095x4095 !
2017-09-27 09:47:25: VideoRecorder: Could not open output file with specified format.
2017-09-27 09:47:25: Could not start video recording
2017-09-27 09:52:41: flt sample format is not supported, s16 will be used
2017-09-27 09:52:41: Preparing to record audio from: Built-in Microph. Channel: 2. Sample rate: 44100. Sample Format: 8
2017-09-27 09:52:58: Start capturing. Mode: Full motion. Method: 0. Capture Size: (2560, 1440)
2017-09-27 09:52:58: Video Codec: flashsv. Expecting FPS: 30.00
2017-09-27 09:52:58: Video will be recorded to: /Users/stephanielee/Library/Application Support/ActivePresenter/temp/rl_20170927_095258_6jg7krg16t_tempdir/video_20170927_09-52-58.mkv
2017-09-27 09:52:58: RLMedia: Input dimensions too large, input must be max 4095x4095 !
2017-09-27 09:52:58: VideoRecorder: Could not open output file with specified format.
2017-09-27 09:52:58: Could not start video recording
2017-09-27 10:07:00: flt sample format is not supported, s16 will be used
2017-09-27 10:07:00: Preparing to record audio from: Built-in Microph. Channel: 2. Sample rate: 44100. Sample Format: 8
2017-09-27 10:07:01: Start capturing. Mode: Full motion. Method: 0. Capture Size: (2560, 1440)
2017-09-27 10:07:01: Video Codec: flashsv. Expecting FPS: 30.00
2017-09-27 10:07:01: Video will be recorded to: /Users/stephanielee/Library/Application Support/ActivePresenter/temp/rl_20170927_100701_dzqc0vpzwx_tempdir/video_20170927_10-07-01.mkv
2017-09-27 10:07:01: RLMedia: Input dimensions too large, input must be max 4095x4095 !
2017-09-27 10:07:01: VideoRecorder: Could not open output file with specified format.
2017-09-27 10:07:01: Could not start video recording
2017-09-27 10:07:34: ActivePresenter 6.1.3 (Release Build: 2017.08.19) shut down
2017-09-27 11:06:37: ActivePresenter 6.1.3 (Release Build: 2017.08.19) started
CPU Count: 8
Computer Name: Stephs-iMac.local. Memory: 16,290 MB. Available: 4,211 MB
Disk Space: 475,936 MB (Free: 336,183 MB)
2017-09-27 11:06:37: TempDir: /Users/stephanielee/Library/Application Support/ActivePresenter/temp
2017-09-27 11:06:58: flt sample format is not supported, s16 will be used
2017-09-27 11:06:58: Preparing to record audio from: Built-in Microph. Channel: 2. Sample rate: 44100. Sample Format: 8
2017-09-27 11:06:59: Start capturing. Mode: Full motion. Method: 0. Capture Size: (2560, 1440)
2017-09-27 11:06:59: Video Codec: flashsv. Expecting FPS: 30.00
2017-09-27 11:06:59: Video will be recorded to: /Users/stephanielee/Library/Application Support/ActivePresenter/temp/rl_20170927_110659_iidvnluah3_tempdir/video_20170927_11-06-59.mkv
2017-09-27 11:06:59: RLMedia: Input dimensions too large, input must be max 4095x4095 !
2017-09-27 11:06:59: VideoRecorder: Could not open output file with specified format.
2017-09-27 11:06:59: Could not start video recording
2017-09-27 11:07:55: Start capturing. Mode: Smart Capture. Method: 0. Capture Size: (2560, 1440)
2017-09-27 11:08:01: Video will be recorded to: /Users/stephanielee/Library/Application Support/ActivePresenter/temp/rl_20170927_110755_4z992nq5jf_tempdir/video_20170927_11-08-01.mkv
2017-09-27 11:08:01: RLMedia: Input dimensions too large, input must be max 4095x4095 !
2017-09-27 11:08:01: VideoRecorder: Could not open output file with specified format.
2017-09-27 11:08:33: Start capturing. Mode: Smart Capture. Method: 0. Capture Size: (2560, 1440)
2017-09-27 11:08:41: Video will be recorded to: /Users/stephanielee/Library/Application Support/ActivePresenter/temp/rl_20170927_110833_s11xluwzbd_tempdir/video_20170927_11-08-41.mkv
2017-09-27 11:08:41: RLMedia: Input dimensions too large, input must be max 4095x4095 !
2017-09-27 11:08:41: VideoRecorder: Could not open output file with specified format.
2017-09-27 11:10:04: flt sample format is not supported, s16 will be used
2017-09-27 11:10:04: Preparing to record audio from: Built-in Microph. Channel: 2. Sample rate: 44100. Sample Format: 8
2017-09-27 11:10:05: Start capturing. Mode: Full motion. Method: 0. Capture Size: (2560, 1440)
2017-09-27 11:10:05: Video Codec: flashsv. Expecting FPS: 30.00
2017-09-27 11:10:06: Video will be recorded to: /Users/stephanielee/Library/Application Support/ActivePresenter/temp/rl_20170927_111005_koopu5rvi5_tempdir/video_20170927_11-10-06.mkv
2017-09-27 11:10:06: RLMedia: Input dimensions too large, input must be max 4095x4095 !
2017-09-27 11:10:06: VideoRecorder: Could not open output file with specified format.
2017-09-27 11:10:06: Could not start video recording
2017-09-27 11:10:58: flt sample format is not supported, s16 will be used
2017-09-27 11:10:58: Preparing to record audio from: Built-in Microph. Channel: 2. Sample rate: 44100. Sample Format: 8
2017-09-27 11:10:59: Start capturing. Mode: Full motion. Method: 0. Capture Size: (2560, 1440)
2017-09-27 11:10:59: Video Codec: libopenh264. Expecting FPS: 30.00
2017-09-27 11:10:59: Video will be recorded to: /Users/stephanielee/Library/Application Support/ActivePresenter/temp/rl_20170927_111059_g60qsp9eba_tempdir/video_20170927_11-10-59.mkv
2017-09-27 11:10:59: bgr24 pixel format is not supported, yuv420p will be used
2017-09-27 11:10:59: RLMedia: [OpenH264] this = 0x0x610000647800, Error:ParamValidationExt(),width(1-4096),height(1-2304)invalid 5120 x 2880 in dependency layer settings!
2017-09-27 11:10:59: RLMedia: [OpenH264] this = 0x0x610000647800, Error:WelsInitEncoderExt(), ParamValidationExt failed return 2.
2017-09-27 11:10:59: RLMedia: [OpenH264] this = 0x0x610000647800, Error:CWelsH264SVCEncoder::Initialize(), WelsInitEncoderExt failed.
2017-09-27 11:10:59: RLMedia: Initialize failed
2017-09-27 11:10:59: VideoRecorder: Could not open output file with specified format.
2017-09-27 11:10:59: Could not start video recording
2017-09-27 12:04:55: flt sample format is not supported, s16 will be used
2017-09-27 12:04:55: Preparing to record audio from: Built-in Microph. Channel: 2. Sample rate: 44100. Sample Format: 8
2017-09-27 12:04:57: Start capturing. Mode: Full motion. Method: 0. Capture Size: (2560, 1440)
2017-09-27 12:04:57: Video Codec: libopenh264. Expecting FPS: 30.00
2017-09-27 12:04:57: Video will be recorded to: /Users/stephanielee/Library/Application Support/ActivePresenter/temp/rl_20170927_120457_6p86jb1fnv_tempdir/video_20170927_12-04-57.mkv
2017-09-27 12:04:57: bgr24 pixel format is not supported, yuv420p will be used
2017-09-27 12:04:57: RLMedia: [OpenH264] this = 0x0x60000065e240, Error:ParamValidationExt(),width(1-4096),height(1-2304)invalid 5120 x 2880 in dependency layer settings!
2017-09-27 12:04:57: RLMedia: [OpenH264] this = 0x0x60000065e240, Error:WelsInitEncoderExt(), ParamValidationExt failed return 2.
2017-09-27 12:04:57: RLMedia: [OpenH264] this = 0x0x60000065e240, Error:CWelsH264SVCEncoder::Initialize(), WelsInitEncoderExt failed.
2017-09-27 12:04:57: RLMedia: Initialize failed
2017-09-27 12:04:57: VideoRecorder: Could not open output file with specified format.
2017-09-27 12:04:57: Could not start video recording
