Continuing the discussion from Unable to record or export mp4:
I have this error in windows 7 pro 64 on latest version of activepresenter.
my best regards
my best regards
Can you please share the log of ActivePresenter, so we can check? To view the log, click ActivePresenter > Preferences > Miscellaneous > View Log.
Sorry but I don’t have the permission to upload.
2020-02-20 07:50:58: ActivePresenter 8.0.1 (Release Build: 2020.02.18) started
OS: Windows 7 (build 7601, Service Pack 1), 64-bit edition. Version: 6.1 - 64 bit
CPU Count: 4
Hostname: SFM-PC. Memory: 18,415 MB. Available: 13,698 MB. Memory Load: 25%
Project Location: C:\Users\SFM\Documents\ActivePresenter
Disk Space: 476,837 MB (Free: 263,563 MB)
2020-02-20 07:50:58: TempDir: C:\Users\SFM\AppData\Roaming\ActivePresenter\temp
2020-02-20 07:50:58: Failed to init Direct2D, GDI+ will be used.
2020-02-20 07:51:11: ActivePresenter 8.0.1 (Release Build: 2020.02.18) shut down
2020-02-20 07:52:23: ActivePresenter 7.5.12 (Release Build: 2020.02.05) started
CPU Count: 4
Hostname: SFM-PC. Memory: 18,415 MB. Available: 13,776 MB. Memory Load: 25%
Disk Space: 476,837 MB (Free: 263,556 MB)
2020-02-20 07:52:23: TempDir: C:\Users\SFM\AppData\Roaming\ActivePresenter\temp
2020-02-20 07:52:23: Failed to init Direct2D, GDI+ will be used.
2020-02-20 07:52:30: ActivePresenter 7.5.12 (Release Build: 2020.02.05) shut down
2020-02-20 07:54:08: ActivePresenter 7.5.12 (Release Build: 2020.02.05) started
CPU Count: 4
Hostname: SFM-PC. Memory: 18,415 MB. Available: 13,732 MB. Memory Load: 25%
Disk Space: 476,837 MB (Free: 263,593 MB)
2020-02-20 07:54:08: TempDir: C:\Users\SFM\AppData\Roaming\ActivePresenter\temp
2020-02-20 07:54:08: Failed to init Direct2D, GDI+ will be used.
2020-02-20 07:54:20: ActivePresenter 7.5.12 (Release Build: 2020.02.05) shut down
2020-02-20 07:55:14: ActivePresenter 6.1.6 (Release Build: 2018.04.16) started
CPU Count: 4
Computer Name: SFM-PC (). Memory: 18,415 MB. Available: 13,652 MB. Memory Load: 25%
Disk Space: 476,837 MB (Free: 263,626 MB)
2020-02-20 07:55:14: TempDir: C:\Users\SFM\AppData\Roaming\ActivePresenter\temp
2020-02-20 07:55:25: Checking updates for ActivePresenter v6.1.6…
2020-02-20 07:56:51: Start capturing. Mode: Full motion. Method: 0. Capture Size: (2560, 1600)
2020-02-20 07:56:51: Video Codec: flashsv. Expecting FPS: 30.00
2020-02-20 07:56:52: Video will be recorded to: C:\Users\SFM\Documents\ActivePresenter\Untitled_tempdir\video_20200220_07-56-52.mkv
2020-02-20 07:56:52: flt sample format is not supported, s16 will be used
2020-02-20 07:56:52: Audio 2 will be recorded to: C:\Users\SFM\Documents\ActivePresenter\Untitled_tempdir\audio_20200220_07-56-52.wav
2020-02-20 07:56:52: Preparing to record audio from: Altoparlanti (Dispositivo High Definition Audio). Channel: 2. Sample rate: 48000. Sample Format: 8
2020-02-20 07:56:52: Failed to open audio stream to record. Error: Invalid device. Retrying with default parameters
2020-02-20 07:56:52: Preparing to record audio from: Altoparlanti (Dispositivo High Definition Audio). Channel: 2. Sample rate: 44100. Sample Format: 8
2020-02-20 07:57:24: Stop video recording. Frames recorded: 795. Dropped: 668. Duration: 29150. Actual FPS: 27.24
2020-02-20 07:57:24: Recorded video data size: 124097 KB
2020-02-20 07:57:24: ProcessRecordedAudio: duration (ms) 29210.021000
2020-02-20 07:57:26: RLMedia: Estimating duration from bitrate, this may be inaccurate
2020-02-20 07:57:28: RLMedia: Estimating duration from bitrate, this may be inaccurate
2020-02-20 07:57:37: Preparing to play audio to: Altoparlanti (Dispositivo High Definition Audio). Channel: 2. Sample rate: 48000. Sample Format: 8
2020-02-20 07:57:37: Could not open audio output stream to play: Invalid device. Retrying with default parameters
2020-02-20 07:57:37: Preparing to play audio to: Altoparlanti (Dispositivo High Definition Audio). Channel: 2. Sample rate: 44100. Sample Format: 8
2020-02-20 07:57:37: RLMedia: Estimating duration from bitrate, this may be inaccurate
2020-02-20 08:00:07: s16 sample format is not supported, fltp will be used
2020-02-20 08:04:04: Error: File ‘C:\Users\SFM\Documents\ActivePresenter\Untitled.approj’ couldn’t be removed (error 32: impossibile accedere al file. Il file è utilizzato da un altro processo.)
2020-02-20 08:04:04: Error: Could not create project file with specified name: C:\Users\SFM\Documents\ActivePresenter\Untitled.approj
2020-02-20 08:04:38: Error: File ‘C:\Users\SFM\Documents\ActivePresenter\Untitled.approj’ couldn’t be removed (error 32: impossibile accedere al file. Il file è utilizzato da un altro processo.)
2020-02-20 08:04:38: Error: Could not create project file with specified name: C:\Users\SFM\Documents\ActivePresenter\Untitled.approj
2020-02-20 08:04:53: ActivePresenter 6.1.6 (Release Build: 2018.04.16) shut down
2020-02-20 08:09:25: ActivePresenter 7.5.12 (Release Build: 2020.02.05) started
CPU Count: 4
Hostname: SFM-PC. Memory: 18,415 MB. Available: 13,762 MB. Memory Load: 25%
Disk Space: 476,837 MB (Free: 274,892 MB)
2020-02-20 08:09:25: TempDir: C:\Users\SFM\AppData\Roaming\ActivePresenter\temp
2020-02-20 08:09:25: Failed to init Direct2D, GDI+ will be used.
2020-02-20 08:09:33: ActivePresenter 7.5.12 (Release Build: 2020.02.05) shut down
2020-02-21 07:23:55: ActivePresenter 7.5.12 (Release Build: 2020.02.05) started
CPU Count: 4
Hostname: SFM-PC. Memory: 18,415 MB. Available: 13,417 MB. Memory Load: 27%
Disk Space: 476,837 MB (Free: 266,433 MB)
2020-02-21 07:23:55: TempDir: C:\Users\SFM\AppData\Roaming\ActivePresenter\temp
2020-02-21 07:23:55: Failed to init Direct2D, GDI+ will be used.
2020-02-21 07:23:59: ActivePresenter 7.5.12 (Release Build: 2020.02.05) shut down
2020-02-21 07:24:34: ActivePresenter 7.5.12 (Release Build: 2020.02.05) started
CPU Count: 4
Hostname: SFM-PC. Memory: 18,415 MB. Available: 13,365 MB. Memory Load: 27%
Disk Space: 476,837 MB (Free: 266,432 MB)
2020-02-21 07:24:34: TempDir: C:\Users\SFM\AppData\Roaming\ActivePresenter\temp
2020-02-21 07:24:34: Failed to init Direct2D, GDI+ will be used.
2020-02-21 07:24:36: ActivePresenter 7.5.12 (Release Build: 2020.02.05) shut down
2020-03-30 08:02:45: ActivePresenter 8.0.4 (Release Build: 2020.03.25) started
CPU Count: 4
Hostname: SFM-PC. Memory: 18,415 MB. Available: 12,838 MB. Memory Load: 30%
Disk Space: 476,837 MB (Free: 273,238 MB)
2020-03-30 08:02:45: TempDir: C:\Users\SFM\AppData\Roaming\ActivePresenter\temp
2020-03-30 08:02:45: Direct3D rendering mode: hardware
2020-03-30 08:02:45: Direct2D failed with HRESULT 80070057
2020-03-30 08:02:45: Failed to init Direct2D, GDI+ will be used.
2020-03-30 08:03:02: ActivePresenter 8.0.4 (Release Build: 2020.03.25) shut down
2020-03-30 08:04:32: ActivePresenter 7.5.13 (Release Build: 2020.03.03) started
CPU Count: 4
Hostname: SFM-PC. Memory: 18,415 MB. Available: 13,215 MB. Memory Load: 28%
Disk Space: 476,837 MB (Free: 273,122 MB)
2020-03-30 08:04:32: TempDir: C:\Users\SFM\AppData\Roaming\ActivePresenter\temp
2020-03-30 08:04:32: Failed to init Direct2D, GDI+ will be used.
2020-03-30 08:04:35: ActivePresenter 7.5.13 (Release Build: 2020.03.03) shut down
2020-03-31 08:13:35: ActivePresenter 8.0.4 (Release Build: 2020.03.25) started
CPU Count: 4
Hostname: SFM-PC. Memory: 18,415 MB. Available: 13,724 MB. Memory Load: 25%
Disk Space: 476,837 MB (Free: 269,432 MB)
2020-03-31 08:13:35: TempDir: C:\Users\SFM\AppData\Roaming\ActivePresenter\temp
2020-03-31 08:13:35: Direct3D rendering mode: hardware
2020-03-31 08:13:35: Direct3D device type: 1
2020-03-31 08:15:06: Warning: cannot initialize COM in MediaFoundation_Capture.
2020-03-31 08:15:06: flt sample format is not supported, s16 will be used
2020-03-31 08:15:06: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2020-03-31 08:15:06: Preparing to record audio from: Altoparlanti (Dispositivo High Definition Audio). Channel: 2. Sample rate: 48000. Sample Format: 8
2020-03-31 08:15:06: Failed to open audio stream to record. Error: Invalid device.
2020-03-31 08:15:06: Preparing to record audio from: Altoparlanti (Dispositivo High Definition Audio). Channel: 2. Sample rate: 44100. Sample Format: 8
2020-03-31 08:17:12: flt sample format is not supported, s16 will be used
2020-03-31 08:17:12: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2020-03-31 08:17:12: Preparing to record audio from: Altoparlanti (Dispositivo High Definition Audio). Channel: 2. Sample rate: 44100. Sample Format: 8
2020-03-31 08:17:43: Error: Cannot stop capture because it seems that the device hasn’t been opened yet.
2020-03-31 08:17:43: ActivePresenter 8.0.4 (Release Build: 2020.03.25) shut down
2020-04-15 14:10:33: ActivePresenter 8.0.4 (Release Build: 2020.03.25) started
CPU Count: 4
Hostname: SFM-PC. Memory: 18,415 MB. Available: 15,099 MB. Memory Load: 18%
Disk Space: 476,837 MB (Free: 266,164 MB)
2020-04-15 14:10:33: TempDir: C:\Users\SFM\AppData\Roaming\ActivePresenter\temp
2020-04-15 14:10:33: Direct3D rendering mode: hardware
2020-04-15 14:10:33: Direct3D device type: 1
2020-04-15 14:10:46: Warning: cannot initialize COM in MediaFoundation_Capture.
2020-04-15 14:10:47: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2020-04-15 14:10:47: Preparing to record audio from: Altoparlanti (Dispositivo High Definition Audio). Channel: 2. Sample rate: 48000. Sample Format: 2147483656
2020-04-15 14:10:47: Failed to open audio stream to record. Error: Invalid device.
2020-04-15 14:10:47: Preparing to record audio from: Altoparlanti (Dispositivo High Definition Audio). Channel: 2. Sample rate: 44100. Sample Format: 8
2020-04-15 14:13:01: Error: Cannot stop capture because it seems that the device hasn’t been opened yet.
2020-04-15 14:13:02: Start capturing. Mode: Full motion. Method: 0. Capture Size: (2211, 1256)
2020-04-15 14:13:02: Video Codec: h264_mf. Expecting FPS: 14.00
2020-04-15 14:13:02: Video will be recorded to: C:\Users\SFM\Documents\ActivePresenter.ActivePresenterCachedProjects\Untitled1_tempdir\video_20200415_14-13-02.mkv
2020-04-15 14:13:02: bgr24 pixel format is not supported, nv12 will be used
2020-04-15 14:13:02: RLMedia: MFT name: ‘H264 Encoder MFT’
2020-04-15 14:13:02: RLMedia: MF Setting Framerate: 14 / 1
2020-04-15 14:13:02: RLMedia: MF Setting Quality: 90
2020-04-15 14:13:02: RLMedia: MF Setting GOPSize: 14
2020-04-15 14:13:02: RLMedia: MF Enabling CABAC FAILED: 0x80004001
2020-04-15 14:13:02: RLMedia: could not set output type (80004005)
2020-04-15 14:13:02: VideoRecorder: Could not open output file with specified format.
2020-04-15 14:13:02: Error: Could not open video encoder
2020-04-15 14:13:22: Error: Cannot stop capture because it seems that the device hasn’t been opened yet.
2020-04-15 14:13:24: PrepareRibbonBar: 1150ms
2020-04-15 14:14:09: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2020-04-15 14:14:09: Preparing to record audio from: Altoparlanti (Dispositivo High Definition Audio). Channel: 2. Sample rate: 44100. Sample Format: 8
2020-04-15 14:14:38: Error: Cannot stop capture because it seems that the device hasn’t been opened yet.
2020-04-15 14:14:39: Start capturing. Mode: Full motion. Method: 0. Capture Size: (2374, 1325)
2020-04-15 14:14:39: Video Codec: h264_mf. Expecting FPS: 14.00
2020-04-15 14:14:39: Video will be recorded to: C:\Users\SFM\Documents\ActivePresenter.ActivePresenterCachedProjects\Untitled1_tempdir\video_20200415_14-14-39.mkv
2020-04-15 14:14:39: bgr24 pixel format is not supported, nv12 will be used
2020-04-15 14:14:39: RLMedia: MFT name: ‘H264 Encoder MFT’
2020-04-15 14:14:39: RLMedia: MF Setting Framerate: 14 / 1
2020-04-15 14:14:39: RLMedia: MF Setting Quality: 90
2020-04-15 14:14:39: RLMedia: MF Setting GOPSize: 14
2020-04-15 14:14:39: RLMedia: MF Enabling CABAC FAILED: 0x80004001
2020-04-15 14:14:39: RLMedia: could not set output type (80004005)
2020-04-15 14:14:39: VideoRecorder: Could not open output file with specified format.
2020-04-15 14:14:39: Error: Could not open video encoder
2020-04-15 14:15:13: Error: Cannot stop capture because it seems that the device hasn’t been opened yet.
2020-04-15 14:15:16: Error: Cannot stop capture because it seems that the device hasn’t been opened yet.
2020-04-15 14:15:16: ActivePresenter 8.0.4 (Release Build: 2020.03.25) shut down
2020-04-15 18:26:03: ActivePresenter 8.0.4 (Release Build: 2020.03.25) started
CPU Count: 4
Hostname: SFM-PC. Memory: 18,415 MB. Available: 13,890 MB. Memory Load: 24%
Disk Space: 476,837 MB (Free: 264,559 MB)
2020-04-15 18:26:03: TempDir: C:\Users\SFM\AppData\Roaming\ActivePresenter\temp
2020-04-15 18:26:03: Direct3D rendering mode: hardware
2020-04-15 18:26:03: Direct3D device type: 1
2020-04-15 18:26:34: Checking updates for ActivePresenter v8.0.4…
2020-04-15 18:26:34: SSL Error: WINHTTP_CALLBACK_STATUS_FLAG_CERT_REV_FAILED failed to check revocation status. WINHTTP_CALLBACK_STATUS_FLAG_INVALID_CA SSL invalid CA.
2020-04-15 18:29:31: ActivePresenter 8.0.5 (Release Build: 2020.04.10) started
CPU Count: 4
Hostname: SFM-PC. Memory: 18,415 MB. Available: 14,926 MB. Memory Load: 18%
Disk Space: 476,837 MB (Free: 264,347 MB)
2020-04-15 18:29:31: TempDir: C:\Users\SFM\AppData\Roaming\ActivePresenter\temp
2020-04-15 18:29:31: Direct3D rendering mode: hardware
2020-04-15 18:29:31: Direct3D device type: 1
2020-04-15 18:29:35: Warning: cannot initialize COM in MediaFoundation_Capture.
2020-04-15 18:29:35: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2020-04-15 18:29:35: Preparing to record audio from: Altoparlanti (Dispositivo High Definition Audio). Channel: 2. Sample rate: 48000. Sample Format: 2147483656
2020-04-15 18:29:35: Failed to open audio stream to record. Error: Invalid device.
2020-04-15 18:29:35: Preparing to record audio from: Altoparlanti (Dispositivo High Definition Audio). Channel: 2. Sample rate: 44100. Sample Format: 8
2020-04-15 18:29:37: Error: Cannot stop capture because it seems that the device hasn’t been opened yet.
2020-04-15 18:29:37: Start capturing. Mode: Full motion. Method: 0. Capture Size: (2374, 1325)
2020-04-15 18:29:37: Video Codec: h264_mf. Expecting FPS: 14.00
2020-04-15 18:29:37: Video will be recorded to: C:\Users\SFM\Documents\ActivePresenter.ActivePresenterCachedProjects\Untitled1_tempdir\video_20200415_18-29-37.mkv
2020-04-15 18:29:37: bgr24 pixel format is not supported, nv12 will be used
2020-04-15 18:29:37: RLMedia: MF Enabling CABAC FAILED: 0x80004001
2020-04-15 18:29:37: RLMedia: could not set output type (80004005)
2020-04-15 18:29:37: VideoRecorder: Could not open output file with specified format.
2020-04-15 18:29:37: Error: Could not open video encoder
2020-04-15 18:29:56: Error: Cannot stop capture because it seems that the device hasn’t been opened yet.
2020-04-15 18:29:59: Error: Cannot stop capture because it seems that the device hasn’t been opened yet.
2020-04-15 18:29:59: ActivePresenter 8.0.5 (Release Build: 2020.04.10) shut down
2020-04-16 12:25:29: ActivePresenter 8.0.5 (Release Build: 2020.04.10) started
CPU Count: 4
Hostname: SFM-PC. Memory: 18,415 MB. Available: 13,481 MB. Memory Load: 26%
Disk Space: 476,837 MB (Free: 268,643 MB)
2020-04-16 12:25:29: TempDir: C:\Users\SFM\AppData\Roaming\ActivePresenter\temp
2020-04-16 12:25:29: Direct3D rendering mode: hardware
2020-04-16 12:25:29: Direct3D device type: 1
2020-04-16 12:25:35: Warning: cannot initialize COM in MediaFoundation_Capture.
2020-04-16 12:25:35: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2020-04-16 12:25:35: Preparing to record audio from: Altoparlanti (Dispositivo High Definition Audio). Channel: 2. Sample rate: 48000. Sample Format: 2147483656
2020-04-16 12:25:35: Failed to open audio stream to record. Error: Invalid device.
2020-04-16 12:25:35: Preparing to record audio from: Altoparlanti (Dispositivo High Definition Audio). Channel: 2. Sample rate: 44100. Sample Format: 8
2020-04-16 12:25:37: Error: Cannot stop capture because it seems that the device hasn’t been opened yet.
2020-04-16 12:25:37: Start capturing. Mode: Full motion. Method: 0. Capture Size: (2374, 1325)
2020-04-16 12:25:37: Video Codec: h264_mf. Expecting FPS: 14.00
2020-04-16 12:25:37: Video will be recorded to: C:\Users\SFM\Documents\ActivePresenter.ActivePresenterCachedProjects\Untitled1_tempdir\video_20200416_12-25-37.mkv
2020-04-16 12:25:37: bgr24 pixel format is not supported, nv12 will be used
2020-04-16 12:25:37: RLMedia: MF Enabling CABAC FAILED: 0x80004001
2020-04-16 12:25:37: RLMedia: could not set output type (80004005)
2020-04-16 12:25:37: VideoRecorder: Could not open output file with specified format.
2020-04-16 12:25:37: Error: Could not open video encoder
2020-04-16 12:25:52: Error: Cannot stop capture because it seems that the device hasn’t been opened yet.
2020-04-16 13:00:03: ActivePresenter 8.0.5 (Release Build: 2020.04.10) started
CPU Count: 4
Hostname: SFM-PC. Memory: 18,415 MB. Available: 13,021 MB. Memory Load: 29%
Disk Space: 476,837 MB (Free: 268,634 MB)
2020-04-16 13:00:03: TempDir: C:\Users\SFM\AppData\Roaming\ActivePresenter\temp
2020-04-16 13:00:03: Direct3D rendering mode: hardware
2020-04-16 13:00:03: Direct3D device type: 1
2020-04-16 13:00:30: Warning: cannot initialize COM in MediaFoundation_Capture.
2020-04-16 13:00:30: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2020-04-16 13:00:30: Preparing to record audio from: Altoparlanti (Dispositivo High Definition Audio). Channel: 2. Sample rate: 48000. Sample Format: 2147483656
2020-04-16 13:00:30: Failed to open audio stream to record. Error: Invalid device.
2020-04-16 13:00:30: Preparing to record audio from: Altoparlanti (Dispositivo High Definition Audio). Channel: 2. Sample rate: 44100. Sample Format: 8
2020-04-16 13:00:31: Error: Cannot stop capture because it seems that the device hasn’t been opened yet.
2020-04-16 13:00:32: Start capturing. Mode: Full motion. Method: 0. Capture Size: (2374, 1325)
2020-04-16 13:00:32: Video Codec: h264_mf. Expecting FPS: 14.00
2020-04-16 13:00:32: Video will be recorded to: C:\Users\SFM\Documents\ActivePresenter.ActivePresenterCachedProjects\Untitled1_tempdir\video_20200416_13-00-32.mkv
2020-04-16 13:00:32: bgr24 pixel format is not supported, nv12 will be used
2020-04-16 13:00:32: RLMedia: MF Enabling CABAC FAILED: 0x80004001
2020-04-16 13:00:32: RLMedia: could not set output type (80004005)
2020-04-16 13:00:32: VideoRecorder: Could not open output file with specified format.
2020-04-16 13:00:32: Error: Could not open video encoder
2020-04-16 13:00:45: Error: Cannot stop capture because it seems that the device hasn’t been opened yet.
2020-04-16 13:00:47: Opening project: C:\Users\SFM\Documents\ActivePresenter\Untitled.approj
2020-04-16 13:00:48: Warning: Resource file not found: C:\Users\SFM\Documents\ActivePresenter\Untitled_files\10000_Video_001.1.mkv
2020-04-16 13:00:48: PrepareRibbonBar: 390ms
2020-04-16 13:00:49: RLMedia: Format matroska,webm detected only with low score of 1, misdetection possible!
2020-04-16 13:00:49: RLMedia: EBML header parsing failed
2020-04-16 13:00:49: Could not open input file [C:\Users\SFM\AppData\Roaming\ActivePresenter\temp\rl_20200416_130049_1zd14uhcex.mkv]
2020-04-16 13:00:49: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2020-04-16 13:00:49: Audio Decoding Stats: Process 78.000000, Wait 0.000000
2020-04-16 13:00:49: Audio Encoding Stats: Process 16.000000, Wait 46.000000
2020-04-16 13:00:59: Opening project: C:\Users\SFM\Documents\ActivePresenter\Untitled.approj
2020-04-16 13:00:59: Warning: Resource file not found: C:\Users\SFM\Documents\ActivePresenter\Untitled_files\10000_Video_001.1.mkv
2020-04-16 13:00:59: RLMedia: Format matroska,webm detected only with low score of 1, misdetection possible!
2020-04-16 13:00:59: RLMedia: EBML header parsing failed
2020-04-16 13:00:59: Could not open input file [C:\Users\SFM\AppData\Roaming\ActivePresenter\temp\rl_20200416_130059_1iisz59vs9.mkv]
2020-04-16 13:01:00: RLMedia: Format matroska,webm detected only with low score of 1, misdetection possible!
2020-04-16 13:01:00: RLMedia: EBML header parsing failed
2020-04-16 13:01:00: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2020-04-16 13:01:00: Audio Decoding Stats: Process 63.000000, Wait 0.000000
2020-04-16 13:01:00: Audio Encoding Stats: Process 0.000000, Wait 47.000000
2020-04-16 13:01:04: Checking updates for ActivePresenter v8.0.5…
2020-04-16 13:01:05: SSL Error: WINHTTP_CALLBACK_STATUS_FLAG_CERT_REV_FAILED failed to check revocation status. WINHTTP_CALLBACK_STATUS_FLAG_INVALID_CA SSL invalid CA.
2020-04-16 13:17:45: Error: Cannot stop capture because it seems that the device hasn’t been opened yet.
2020-04-16 13:17:45: ActivePresenter 8.0.5 (Release Build: 2020.04.10) shut down
2020-04-16 15:01:57: ActivePresenter 8.0.5 (Release Build: 2020.04.10) started
CPU Count: 4
Hostname: SFM-PC. Memory: 18,415 MB. Available: 12,660 MB. Memory Load: 31%
Disk Space: 476,837 MB (Free: 267,500 MB)
2020-04-16 15:01:57: TempDir: C:\Users\SFM\AppData\Roaming\ActivePresenter\temp
2020-04-16 15:01:57: Direct3D rendering mode: hardware
2020-04-16 15:01:57: Direct3D device type: 1
2020-04-16 15:02:28: Checking updates for ActivePresenter v8.0.5…
2020-04-16 15:02:28: SSL Error: WINHTTP_CALLBACK_STATUS_FLAG_CERT_REV_FAILED failed to check revocation status. WINHTTP_CALLBACK_STATUS_FLAG_INVALID_CA SSL invalid CA.
2020-04-16 15:02:50: Warning: cannot initialize COM in MediaFoundation_Capture.
2020-04-16 15:02:50: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2020-04-16 15:02:50: Preparing to record audio from: Altoparlanti (Dispositivo High Definition Audio). Channel: 2. Sample rate: 48000. Sample Format: 2147483656
2020-04-16 15:02:50: Failed to open audio stream to record. Error: Invalid device.
2020-04-16 15:02:50: Preparing to record audio from: Altoparlanti (Dispositivo High Definition Audio). Channel: 2. Sample rate: 44100. Sample Format: 8
2020-04-16 15:03:25: Error: Cannot stop capture because it seems that the device hasn’t been opened yet.
2020-04-16 15:03:25: Start capturing. Mode: Full motion. Method: 0. Capture Size: (2374, 1325)
2020-04-16 15:03:25: Video Codec: h264_mf. Expecting FPS: 14.00
2020-04-16 15:03:25: Video will be recorded to: C:\Users\SFM\Documents\ActivePresenter.ActivePresenterCachedProjects\Untitled1_tempdir\video_20200416_15-03-25.mkv
2020-04-16 15:03:25: bgr24 pixel format is not supported, nv12 will be used
2020-04-16 15:03:25: RLMedia: MF Enabling CABAC FAILED: 0x80004001
2020-04-16 15:03:25: RLMedia: could not set output type (80004005)
2020-04-16 15:03:25: VideoRecorder: Could not open output file with specified format.
2020-04-16 15:03:25: Error: Could not open video encoder
2020-04-16 15:03:44: Error: Cannot stop capture because it seems that the device hasn’t been opened yet.
Thanks for sharing the log.
ActivePresenter on Windows 7 only supports up to Full HD resolution (1920x1080) when exporting video. Please consider to reduce the output video resolution (select < 100% ratio or create smaller project) or upgrade to Windows 10 to resolve the issue.
I used 1920x1080 but I have the same error that starts at recording start.
I don’ t the ability to upload video. if you enable me I’ll upload a video too.
Best regards
I have checked the log again and seen that a Windows Component is missing or failed to init on your computer (Warning: cannot initialize COM in MediaFoundation_Capture).
Please try updating Windows or:
Then, you can convert the exported videos to MP4 with Handbrake (https://handbrake.fr/) as a workaround.
Active presenter works properly after total windows update at 1920x1080
Best regard
Thanks for your information. We are glad to hear that it works now.
