Hi
what can I do withe this error
Activepresenter Error
Could not create default object templates
Details
File 'C:lUserslNabiI NasshaatlDocumentslActivePresenter TemplateslDefauIt
2019-07-13 17:54:16: File ‘C:\Users\Nabil Nasshaat\Documents\ActivePresenter Templates\Default.apobject’ couldn’t be removed (error 5: Access is denied.)
2019-07-13 17:54:16: Could not create default object templates
It seems there is a problem with ActivePresenter Templates folder %USERPROFILE%\Documents\ActivePresenter Templates. Please make sure it is not on a network drive. Or the file Default.apobject is locked, you should find this file in the templates folder and remove it. After that, please restart ActivePresenter to check the problem.
Can you please check the permission for the folder ActivePresenter Templates.
In some case, its permission is set to an network account but the current account is local, especially in enterprise environment.
Hello,
I have downloaded the version 8 software for windows 10 and I am getting this same message when trying to open the application “Could not create default object templates.” I am also unable to record anything in the app and get error message “could not create project file…” I am able to pull up the security folder for activePresenter Templates as shown above and cannot see anything strange. Please advise and thank you for your help!
Some users said that they accidentally clicked the Block App instead of Allow App option in the antivirus software which led to this problem. You can add ActivePresenter to its whitelist to overcome this issue.
You might be using a directory which is synchronized by onedrive or dropbox.
If you create the “\ActivePresenter” and “\ActivePresenter Templates” directly under c:\ or c:\users\yourusername then it should work
