It is not possible to copy/paste javascript code from one to another symbol?
Also when I copy a Run Javascript (on Mouse click), the software crashes…
Thanks
Thanks
Hi Pim,
Thank you for reporting the bug when copying a Run JavaScript action in a symbol.
We’ll fix it in the next update.
JavaScript functions are shared among symbols in a project, so you don’t need to copy/paste a function from one symbol to another. Just add a Run JavaScript action, click Change Function and select a function from the list.
Ah yes that works:-) Thanks a million.
