Problem: When I copy and paste a slide in AP 8, the name of slide don’t change like AP 7 (taking the number of slide order). Using Go to slide interaction is more difficult due similar slide names.
ActivePresenter Version: 8.0.0
OS: Windows 10
OS: Windows 10
It’s a bug in ActivePresenter 8. We will fix it soon.
Please remove the slide name in Properties pane to fix the problem.
We are sorry for the inconvenience.
