Hi! Is it possible to control the rotation of a 3D object (whatever extension) through buttons? For example, as I click a button multiple times, the 3D object matches that coordinate. or, if I click the button, it goes to the Y rfotation at 360…
Unfortunately, ActivePresenter 9 does not allow it at this time. Hopefully the following version will include this 3D rotation feature.
I can only think of one workaround: modify the rotation values using the object state, then use a number variable and events-actions to make it work. Here is a sample project for your reference.
