Continuous scribbling
Is there a way to have a continuous scribbling? I would like to do some writing on the screen, but as the freeform scribbles stops as soon as yourelease the mouse and goes back into select mode this is not possible. If it would go back to scribble mode instead of select mode, it should be possible.
So is there a way to make the system go back to freeform scribble mode per default?
Or any way how to add pen support?
Thx
Marcus
Hi Marcus,
Unfortunately, this is not supported in the current version of ActivePresenter. We will consider to support it if there are more requests from users.
