For some time there has been a series of crashes at program startup and I can not determine the reason … to show, I record the video of the link below.
Thanks for sharing the log. We have taken a look but no could not find out the cause of issue. Is there any Error Reporting dialog appearing after the crashes? If yes, please fill your email and click Report Error.
No, it only appears what I sent in the video, a box saying that the program stopped working … I already looked at the log, I already disabled programs and I already noticed the folder “temp”, in an attempt to discover a relation with the problem…
I could not find anything that could be more precise …
After several observations, I was able to find out which program is causing the crashes in the Activepresenter, is the Foxit Reader.
No matter the time it is opened, Active Hangs.
If I open Active, before Foxit, Active works perfectly, no problems or crashes, however, when I open Foxit, when I go back to Active, even without closing it, it hangs … being necessary to ask for the Windows cancel the process.
In this situation, even if you close and reopen Active, it continues to lock in the same way, so you need to restart your computer before you can use it again.
If you open Foxit before Active, Active opens and hangs, and you need to restart your computer to continue working with Active.
