Problem: Active Presenter doesn’t start (showing the “Initializing Media”-Information without further booting), when Rode NT-USB Mini Mic is plugged in. Works well, when mic is unplugged. Does anyone have the same problem and is there any fix available? Thanks for your help.
Hi Yen,
thanks a lot for your kind help. Following your advice I could fix the issue by uninstalling Rode Connect and the additional Rode virtual audio device. Is there any chance to have both devices working together in the future?
Kind regards
I.
