Problem: Closed Captioning appears in one large, word wrapped text box on the slide.
I have used the text to speech feature to insert audio to each slide from a PowerPoint import. I would like to use the text for Closed Captioning. The only way I have found to do this is to insert snippets of the text while aligning the snippets to the audio. Is there a way to have the closed captioning span the entire length of the audio or the length of the slide timing?
Thank you.
ActivePresenter version: ActivePresenter Pro Edition Version 9.0.6
OS: Windows 11 64 Bit
Hi Carlos,
At this time, ActivePresenter hasn’t supported this case yet.
You can copy text to the text document > edit it following the srt format then import it to ActivePresenter as a workaround.
Best regards,
Hello and thank you for your response.
This is in response to your email.
I am familiar with converting closed captioning into audio and have tried to use that feature. That is not what I am trying to do.
I have a one minute script for each slide. I have uploaded the script and have the software generate the audio from it. I would like to use the script to populate the closed captioning.
I do not need audio in the background.
I hope that makes sense.
Thank you.
~Carlos.
Hi Carlos,
Thank you for your explanation.
Please consider my suggestion in the above response as a workaround for this case.
Have a good day,
