Closed caption color and position
Is it possible to change the color and/or position of the closed caption block? The position at the bottom is blocking the view of some of the controls in our application?
ActivePresenter Version: 7.0.1
OS: Win 10
You can change the color of closed caption by selecting it, then go to the Properties pane and change the options in the Fill section. Changing the position of closed caption is not supported in the current version of ActivePresenter.
I see how to change the fill color. Is it possible to change the color of the text?
You just need to select the Closed Caption, go to the Home tab, in the Font group then select the Text Color tool.
is ist possible to change the postition of the closed caption in version 8?
Thank you
Selina
Hi Selina,
Unfortunately, changing the position of closed caption is not supported in version 8.
Yen
