Hello all,
I’m trying to clear the text from a drop target by script.
I run the below line on “On Accept” and it works fine:
prez.object(“Drop Target_7”).text("");
But to re-use it easily on many drop targets I’m wondering if there is a way to do something like:
prez.object(this).text("");
prez.object(this.object).text("");
I tried both but it does not seem to work. Is there a way to get the object on which the “On Accept” is set without using the objects name?
Thanks,
In any JavaScript action, you can use the following variables:
this: the current target object that handles the event.
e: the event object. It may provide some useful information for some events. For example, e.value in a On Accept event is the drag source that is dropped.
prez: the presentation.
AP: the player.
So to clear text from a drop target in its On Accept event, just use this.text('');.
