ntitce
October 21, 2019, 8:13am
1
I have install ActivePresenter and my usual working interface will be Traditional Chinese.
When I open this program at the first time, I cannot create a new blank project (as attached file). I have try to uninstall and re-install this program, but the new blank project still cannot be created.
Is anyone could give me any advice?
Thank you.
ActivePresenter Version:
7.5.9 (Pro Edition)
OS:
Windows 10 64bit
error picture
phuongdv
(Dao Viet Phuong)
October 22, 2019, 1:14am
2
Can you please share the log of ActivePresenter? To view the log, click Preferences (the Gear icon) > Miscellaneous > View Log.
ntitce
October 22, 2019, 2:21am
3
Sorry, some of the log is Traditional Chinese.
2019-10-20 09:26:04: ActivePresenter 7.5.8 (Release Build: 2019.06.27) started
OS: Windows 10 (build 18362), 64-bit edition. Version: 10.0 - 64 bit
CPU Count: 4
Hostname: DESKTOP-9S4J2D3. Memory: 8,089 MB. Available: 3,944 MB. Memory Load: 51%
Project Location: C:\Users\user\Documents\ActivePresenter
Disk Space: 0 MB (Free: 0 MB)
2019-10-20 09:26:04: TempDir: C:\Users\user\AppData\Roaming\ActivePresenter\temp
2019-10-20 09:26:07: PrepareRibbonBar: 1677ms
2019-10-20 09:26:08: 錯誤: 目錄 ‘C:\Users\user\Documents\ActivePresenter Templates’ 無法建立 (錯誤 2: 系統找不到指定的檔案。)
2019-10-20 09:26:08: 錯誤: Could not create default object templates
2019-10-20 09:26:19: 錯誤: 目錄 ‘C:\Users\user\Documents\ActivePresenter’ 無法建立 (錯誤 2: 系統找不到指定的檔案。)
2019-10-20 09:26:19: 錯誤: 無法創建指定文件名工程文件:C:\Users\user\Documents\ActivePresenter.ActivePresenterCachedProjects\未命名
2019-10-20 09:26:24: 錯誤: 目錄 ‘C:\Users\user\Documents\ActivePresenter’ 無法建立 (錯誤 2: 系統找不到指定的檔案。)
2019-10-20 09:26:24: 錯誤: 無法創建指定文件名工程文件:C:\Users\user\Documents\ActivePresenter.ActivePresenterCachedProjects\未命名
2019-10-20 09:26:35: Checking updates for ActivePresenter v7.5.8…
2019-10-20 09:26:36: New updates available: 7.5.9
2019-10-20 09:27:07: Downloading updates to: C:\Users\user\AppData\Local\Temp\ActivePresenter_updater_tmp\ActivePresenter_v7.5.9_update.zip
2019-10-20 09:27:07: Download size: 45.0 MB
2019-10-20 09:27:29: Download completed
2019-10-20 09:27:57: Extracting [C:\Users\user\AppData\Local\Temp\ActivePresenter_updater_tmp\ActivePresenter_v7.5.9_update.zip] to [C:\Users\user\AppData\Local\Temp\ActivePresenter_updater_tmp\setup]…
2019-10-20 09:29:52: Executing [C:\Users\user\AppData\Local\Temp\ActivePresenter_updater_tmp\rlupdater.exe C:\Program Files\ATOMI\ActivePresenter\ActivePresenter.exe C:\Users\user\AppData\Local\Temp\ActivePresenter_updater_tmp\setup\ActivePresenter_v7.5.9_update.exe]…
2019-10-20 09:29:52: Running updater…
2019-10-20 09:29:52: ActivePresenter 7.5.8 (Release Build: 2019.06.27) shut down
2019-10-20 09:30:38: ActivePresenter 7.5.9 (Release Build: 2019.08.23) started
CPU Count: 4
Hostname: DESKTOP-9S4J2D3. Memory: 8,089 MB. Available: 4,070 MB. Memory Load: 49%
2019-10-20 09:30:39: TempDir: C:\Users\user\AppData\Roaming\ActivePresenter\temp
2019-10-20 09:30:57: PrepareRibbonBar: 16763ms
2019-10-20 09:30:58: 錯誤: 目錄 ‘C:\Users\user\Documents\ActivePresenter Templates’ 無法建立 (錯誤 2: 系統找不到指定的檔案。)
2019-10-20 09:30:58: 錯誤: Could not create default object templates
2019-10-20 09:31:44: 錯誤: 目錄 ‘C:\Users\user\Documents\ActivePresenter’ 無法建立 (錯誤 2: 系統找不到指定的檔案。)
2019-10-20 09:31:44: 錯誤: 無法創建指定文件名工程文件:C:\Users\user\Documents\ActivePresenter.ActivePresenterCachedProjects\未命名
2019-10-20 09:31:49: 錯誤: 目錄 ‘C:\Users\user\Documents\ActivePresenter’ 無法建立 (錯誤 2: 系統找不到指定的檔案。)
2019-10-20 09:31:49: 錯誤: 無法創建指定文件名工程文件:C:\Users\user\Documents\ActivePresenter.ActivePresenterCachedProjects\未命名
2019-10-20 09:32:17: 錯誤: 目錄 ‘C:\Users\user\Documents\ActivePresenter’ 無法建立 (錯誤 2: 系統找不到指定的檔案。)
2019-10-20 09:32:17: 錯誤: 無法創建指定文件名工程文件:C:\Users\user\Documents\ActivePresenter.ActivePresenterCachedProjects\未命名
2019-10-20 09:32:32: 錯誤: 目錄 ‘C:\Users\user\Documents\ActivePresenter’ 無法建立 (錯誤 2: 系統找不到指定的檔案。)
2019-10-20 09:32:32: 錯誤: 無法創建指定文件名工程文件:C:\Users\user\Documents\ActivePresenter.ActivePresenterCachedProjects\未命名
2019-10-20 09:32:41: flt sample format is not supported, s16 will be used
2019-10-20 09:32:41: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2019-10-20 09:32:41: Preparing to record audio from: . Channel: 2. Sample rate: 48000. Sample Format: 8
2019-10-20 09:32:49: flt sample format is not supported, s16 will be used
2019-10-20 09:32:49: RLMedia: Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
2019-10-20 09:32:49: Preparing to record audio from: . Channel: 2. Sample rate: 48000. Sample Format: 8
2019-10-20 09:32:58: 錯誤: 目錄 ‘C:\Users\user\Documents\ActivePresenter’ 無法建立 (錯誤 2: 系統找不到指定的檔案。)
2019-10-20 09:32:58: 錯誤: 無法創建指定文件名工程文件:C:\Users\user\Documents\ActivePresenter.ActivePresenterCachedProjects\未命名
2019-10-20 09:33:15: 錯誤: 目錄 ‘C:\Users\user\Documents\ActivePresenter’ 無法建立 (錯誤 2: 系統找不到指定的檔案。)
2019-10-20 09:33:15: 錯誤: 無法創建指定文件名工程文件:C:\Users\user\Documents\ActivePresenter.ActivePresenterCachedProjects\未命名
2019-10-20 09:35:44: ActivePresenter 7.5.9 (Release Build: 2019.08.23) shut down
Jtheman
October 22, 2019, 12:35pm
4
Do you have enough drive space?
I had a problem when my C drive was full… (with overcrowded AppData folder)
hope it helps…
best
ntitce
October 22, 2019, 1:15pm
5
Thanks for your information.
The HD C still have 121GB.
dangle
(Dan Le)
October 22, 2019, 1:18pm
6
From what the logs say, ActivePresenter wasn’t able to create the project file at that location.
You can try the following:
Make sure ActivePresenter is not running.
Find and delete the configuration file: “C:\Users\user\AppData\Roaming\ActivePresenter\ActivePresenter.apconfig”
Make sure that you have write permissions in the folder “C:\Users\user\Documents\ActivePresenter”
Start ActivePresenter and try again.
