Problem: Can proportions be kept when resizing all elements at same time?
Saola Animate version: Required. 2.7.1
OS: Required. Windws 10
When I try to resize all elements at same time by first selecting all elements and then click and drag to resize, everything loses it’s proportion to each other. Can all the elements be selected and resized while maintaining proportions to each other?
Saola Animate resize all selected elements by the same amount, so it doesn’t maintain proportions between elements. Maybe we should change the way it works to keep the proportions.
That would be a very useful new feature! Sometimes after doing a layout with a lot of elements and shapes, I want to make everything a little larger or smaller and it takes a lot of time to resize one by one. Other times it may just be 3 or 4 or 5 elements I want to resize and it’s so much faster if I can drag and select them, and then grab and drag one of the sizing nodes and do them all at once.
