Dear support,
I’m currently facing a problem with states in my Christmas calendar presentation:
On my starting slide I have several button objects with the states “Normal” “Disabled” and “Visited”.
Onclick I change the state (to Visited), forward to a specific slide and then go back to the starting slide.
This works so far, however if I come back and mouseover a button the button’s state seems to change. However this behaviour is not implemented and there is now Rollover action assigned to the button. If I reload the starting slide the states are set correctly.
Do you have any hints how to identify the problem?
Best wishes
Ludger
ActivePresenter version: 8.5.2
OS: Windows 10
