Problem: The button does not look the same after publishing
ActivePresenter Version: 7.0.1
OS: Windows 7
Notes: When I export to HTML5, the button is wrapping the text. It does not appear this way when viewing the slide. Only after exporting. I used the same settings for this button on previous lessons I created. I’ve confirmed they are the same size, but in this lesson the text is wrapping.
This is a known issue in ActivePresenter when exporting to HTML5. The reason is the browser measures text differently from the ActivePresenter editor. You need to extend the width of button a little bit to avoid line breaking. We will try to fix this problem in the future releases.
