Is it possible to bulk edit all the slides in a project?
So for example I want to make all the slides 5 seconds with out going to each one and dragging them individually to 5 seconds;
Yes, but it only works with some properties. In your case, you can select the slides in the Slides pane on the left , then go to the Properties pane on the right to set their duration.
thanks so much! super helpful
