Bugs, report, "Anwort des Lernenden"
Dear support,
in the German version of the Scorm export the report says “Anwort des Lernenden”. Actually it should be “Antwort des Lernenden” (t is missing).
Also in the report the section %apDetailedResult% by default appears twice and I have to remove it manually.
Best wishes
Ludger
ActivePresenter version: 8.5
OS: Windows 10
Hi Ludger,
Thanks for reporting the issues.
They will be fixed in the next update.
