2022-10-19 10:16:09: ActivePresenter 9.0.1 - 64-bit build. (Release Build: 2022.10.06) started
OS: macOS Monterey Version 12.6 (Build 21G115)
CPU Count: 8
Hostname: Arnits-MacBook-Pro. Memory: 15,764 MB. Available: 10,711 MB. Memory Load: 32%
Disk Space: 471,482 MB (Free: 145,122 MB)
Project Location: /Users/arnitdey/Documents/ActivePresenter/
2022-10-19 10:16:09: TempDir: /Users/arnitdey/Library/Application Support/ActivePresenter/temp
2022-10-19 10:16:09: ---------------------LISTING AUDIO DEVICES------------------------
2022-10-19 10:16:09: MacBook Pro Microphone (API: Core Audio, Input: 1, Output: 0, Rate: 48000, Loopback: false, Default Output: false, ID: 51)
2022-10-19 10:16:09: MacBook Pro Speakers (API: Core Audio, Input: 0, Output: 2, Rate: 48000, Loopback: false, Default Output: true, ID: 44)
2022-10-19 10:16:09: --------------------------------------------------------------
2022-10-19 10:16:42: Opening project: /Users/arnitdey/Documents/active/73.approj
2022-10-19 10:16:42: Warning: Resource file not found: /Users/arnitdey/Documents/active/73_files/10000_Video_001.mkv
2022-10-19 10:16:43: PrepareRibbonBar: 823ms
2022-10-19 10:16:43: RLSQLite exception 1, SQL logic error[1]: cannot open value of type null
2022-10-19 10:16:44: RLMedia: No accelerated colorspace conversion found from yuv420p to argb.
2022-10-19 10:16:58: Render Project Size: 1366 x 768
2022-10-19 10:16:58: Threads Used: 1 / 8, Memory Available: 9,811/15,764
2022-10-19 10:16:58: Probing to play audio from: MacBook Pro Speakers. Channel: 2. Sample rate: 48000. Pa Sample Format: 8
2022-10-19 10:16:58: Open audio device successes!
2022-10-19 10:17:07: Render Project Size: 1366 x 768
2022-10-19 10:17:07: Threads Used: 1 / 8, Memory Available: 9,691/15,765
2022-10-19 10:17:07: Probing to play audio from: MacBook Pro Speakers. Channel: 2. Sample rate: 48000. Pa Sample Format: 8
2022-10-19 10:17:07: Open audio device successes!
2022-10-19 10:17:20: Render Project Size: 1366 x 768
2022-10-19 10:17:20: Threads Used: 1 / 8, Memory Available: 9,642/15,765
2022-10-19 10:17:20: Probing to play audio from: MacBook Pro Speakers. Channel: 2. Sample rate: 48000. Pa Sample Format: 8
2022-10-19 10:17:20: Open audio device successes!
2022-10-19 10:17:52: ActivePresenter 9.0.1 (Release Build: 2022.10.06) shut down
2022-10-19 10:18:02: ActivePresenter 9.0.1 - 64-bit build. (Release Build: 2022.10.06) started
CPU Count: 8
Hostname: Arnits-MacBook-Pro. Memory: 15,765 MB. Available: 10,571 MB. Memory Load: 32%
Disk Space: 471,482 MB (Free: 147,805 MB)
2022-10-19 10:18:02: TempDir: /Users/arnitdey/Library/Application Support/ActivePresenter/temp
2022-10-19 10:18:02: ---------------------LISTING AUDIO DEVICES------------------------
2022-10-19 10:18:02: MacBook Pro Microphone (API: Core Audio, Input: 1, Output: 0, Rate: 48000, Loopback: false, Default Output: false, ID: 51)
2022-10-19 10:18:02: MacBook Pro Speakers (API: Core Audio, Input: 0, Output: 2, Rate: 48000, Loopback: false, Default Output: true, ID: 44)
2022-10-19 10:18:02: --------------------------------------------------------------
2022-10-19 10:18:05: Opening project: /Users/arnitdey/Documents/active/73.approj
2022-10-19 10:18:05: Warning: Resource file not found: /Users/arnitdey/Documents/active/73_files/10000_Video_001.mkv
2022-10-19 10:18:06: PrepareRibbonBar: 625ms
2022-10-19 10:18:06: RLSQLite exception 1, SQL logic error[1]: cannot open value of type null
2022-10-19 10:18:06: RLMedia: No accelerated colorspace conversion found from yuv420p to argb.
2022-10-19 10:18:16: Render Project Size: 1366 x 768
2022-10-19 10:18:16: Threads Used: 1 / 8, Memory Available: 9,119/15,764
2022-10-19 10:18:16: Probing to play audio from: MacBook Pro Speakers. Channel: 2. Sample rate: 48000. Pa Sample Format: 8
2022-10-19 10:18:16: Open audio device successes!
2022-10-19 10:18:29: Render Project Size: 1366 x 768
2022-10-19 10:18:29: Threads Used: 1 / 8, Memory Available: 7,848/15,765
2022-10-19 10:18:29: Probing to play audio from: MacBook Pro Speakers. Channel: 2. Sample rate: 48000. Pa Sample Format: 8
2022-10-19 10:18:29: Open audio device successes!
2022-10-19 10:18:36: Render Project Size: 1366 x 768
2022-10-19 10:18:36: Threads Used: 1 / 8, Memory Available: 8,435/15,769
2022-10-19 10:18:36: Probing to play audio from: MacBook Pro Speakers. Channel: 2. Sample rate: 48000. Pa Sample Format: 8
2022-10-19 10:18:36: Open audio device successes!
2022-10-19 10:18:45: Render Project Size: 1366 x 768
2022-10-19 10:18:45: Threads Used: 1 / 8, Memory Available: 8,375/15,769
2022-10-19 10:18:45: Probing to play audio from: MacBook Pro Speakers. Channel: 2. Sample rate: 48000. Pa Sample Format: 8
2022-10-19 10:18:45: Open audio device successes!
